Author Topic: Trouble with Merging Points  (Read 25903 times)
Harry4
« on: June 27, 2014, 04:24:11 pm »
Hi there,
I am having difficulty merging points. I select two points, click "Merge Points" in the "Edit" drop down menu, and select the maximum distance, but nothing ever happens. I have even tried to see if it would work if I set the maximum distance to 100 (I have also tried values as low as 0.001). But still nothing. I also have the most recent version of Anim8or.
Any suggestions?
Harry4
neighborlee
Re: Trouble with Merging Points
« Reply #1 on: June 27, 2014, 05:44:45 pm »
Hi there,
Any suggestions?
Harry4
I'm new here as well, but love modeling/animating , etc, doing it for game development on my end.
I tried to merge at '0', but it won't do it, maybe scale works there, yet to try it.
I can get merge 100 or greater to work.
If you want realtime help, come over to irc.freenode.net, #amim8tor ;)
Good luck Harry
nl
« Reply #2 on: June 27, 2014, 06:29:05 pm »
Make sure the points belong to the same mesh. If they're from two separate meshes, select the two meshes and go to Build->Join Solids.
If they're extremely far apart and you can't figure out the distance, try moving the points closer together. You can also double click on a point and input the coordinates by hand, if you wish to be exact.
neighborlee
« Reply #3 on: June 27, 2014, 06:32:49 pm »
Speaking of points or lines..
Is there no way atm, to manually select points or lines, vs drawing  a rectangle around, which isn't precise ?
I read pertinent part of manual, but I saw no mention of this.
ty
nl
« Last Edit: June 27, 2014, 06:33:10 pm by neighborlee »
« Reply #4 on: June 27, 2014, 06:39:19 pm »
The manual is the best source for basic information: http://anim8or.com/learn/manual/4_object_editor.html#object_point_operations
As you might imagine, using the select tool with the proper element selected -- point/edge/face () -- allows you to individually select a point, edge, or face for further manipulation.
neighborlee
« Reply #5 on: June 27, 2014, 07:56:28 pm »
DRats, Im really sorry I wasn't clear..I meant..to select several verts,by like shift select , vs having to lasso them..
That comes in very handy when lasso'ing can be tricky.
I realize one can zoom,but that's a headache sometimes too.
anyway, just wondering.
ty
nl
« Reply #6 on: June 27, 2014, 08:01:42 pm »
Right-click adds, middle-click subtracts
neighborlee
« Reply #7 on: June 27, 2014, 08:07:41 pm »
Ok thanks a bunch, I clearly missed the MMB reference in manual. I read a lot , clearly I missed that , sigh.
Very excellent, ty so much raxx.
nl
neighborlee
« Reply #8 on: June 28, 2014, 01:16:09 pm »
On further inspection, I'm not even finding where the manual says anything about MMB or RMB for dealing with points , etc.
It would be helpful to point it out for those who may not have time to peruse a entire manual before starting to work with Aim8tor ;)
ty
nl
« Reply #9 on: June 28, 2014, 04:44:23 pm »
It's very nearly the first thing mentioned in the manual, under Chapter 2: Mouse Usage
