Author Topic: best widescreen size  (Read 12802 times)
« on: July 12, 2008, 11:47:53 pm »
hay does anyone know or would suggest the best HD Widescreen size.
Re: best widescreen size
« Reply #1 on: July 13, 2008, 02:27:20 am »
16:9, for HD I'd suggest 1920x1080 (or is that Blu-ray)
You might find a better example through a Google search.
« Reply #2 on: July 13, 2008, 07:34:39 am »
1080p or 1920x1080 is standard full HD widescreen size. But almost everything with ratio 16:9 or 16:10 will do and make an nice render.
Deraga
« Reply #3 on: July 13, 2008, 11:13:05 pm »
16:9 is manly the tv. Movie studios use different aspect ratios, that is why you will get the black bars on top and bottom of the movie on a widescreen tv.
indy1333
« Reply #4 on: July 14, 2008, 02:11:42 pm »
As previously mentioned, 1920 x 1080 , or 1080p, is full HD resolution, and is in the 16:9 aspect ratio. (16:9 is the aspect ratio of most widescreen TV's, 16:10 is the aspect ratio of most widescreen monitors.) But if a frame that large takes too long to render, the other popular widescreen size is 1280 x 720, otherwise known as 720p. This is also in the 16:9 aspect ratio, and will do for pretty much any high definition presentation, unless it is being mixed with video of  higher resolution, in which case it would be good to go for 1080p.
Blu-Ray, HD-DVD, and every other medium all use the same resolutions for presenting High Definition video; the differences are the type of disc (blue or red laser) being used and the hardware being used to read and display them.
« Reply #5 on: July 18, 2008, 10:11:58 pm »
Thanks this will make it look way better. Now when I put it on my cousins 50" or on my HD 37" that Im soon getting it will look a whole lot better.(:
