Author Topic: Script Request - Duplicate objects based in points (mesh2path_2.a8s) modified ?  (Read 12344 times)
Hi All,
is possible to charger "mesh2path_2.a8s" to duplicate objects BASED ONLY IN THE POINTS and axis X,Y and Z of mesh?
follow sample:
for generate hair, grass etc...
.a8s for download?
(PS: the Standalone Grassgen software don´t work right in rounded objects and axis Y).
I believe then a8s. script work better!!
Thanks all!
- Sorry my english ok, i´m not americam
Neirao - Brazil
« Last Edit: July 07, 2008, 11:17:43 pm by neirao »
xalener
Well, I can't do scripts, so I can't help.......but this does look like a good idea.
NickE
There is already a script that can do that.  Carefully read this topic (especially the last post):
http://www.anim8or.com/smf/index.php?topic=906.0
Be sure to use the final version of the script:
http://www.anim8or.com/smf/index.php?action=dlattach;topic=906.0;attach=1080
The previous versions posted in that topic do not do what you want.  The final version is not a parametric script, but is very flexible.  You can choose whether shapes are copied to just the points, just the faces, or both.
 :D Thank you again NickiE,
for forum to have very topics, i lose it, and no has read.
you are great! ;)
Neirão -  Brazil
