Author Topic: rocks  (Read 7081 times)
mak
rocks
« on: June 29, 2008, 06:31:04 pm »
im making a character made of rocks. it seems simple enough but i cant seem to make a decent looking rock. any sugestions?
realisim is for reality
B3dman
Re: rocks
« Reply #1 on: June 30, 2008, 12:09:32 am »
you can find a rock plug in at this website(and alot of other plugins) http://homepage.ntlworld.com/w.watson3/main/parameteric.html
i hope this plug in works the way you want it to if not i have a few more tricks up my sleeve ;)
Galatians 5:6
mak
Re: rocks
« Reply #2 on: July 02, 2008, 07:24:28 pm »
thank you B3dman. i think thats exactly what i need. one thing though every time i open anim8or i get a black screen that says; compiling ".\rocks.a8s" 104lines 0 errors. and if i close it anim8or shuts down, i could probable live with it, but can i get rid of it?
id be curious what you oth tricks might be just out of curiosity.
B3dman
Re: rocks
« Reply #3 on: July 02, 2008, 11:34:11 pm »
well the "black screen" is nothing to worry about its called a debug screen, it basically makes sure that the scripts you have are written properly so that you wont have a problem with them while you are in anim8or so dont worry about that. and as to other tricks this one will probably work better on second thought.
use the "add primitive mesh" tool(shift+M) and then convert it to a subdivided. then go to point edit mode and move around the points it looks very realistic if you do it right here is a render of rocks i made with this technique(it also works with other shapes like spheres and cubes so experiment ;) )
Galatians 5:6
