Author Topic: A newbie trying to model a space ship (help!)  (Read 9787 times)
Lachie Dazdarian
    • The Maker of Stuff
« on: June 25, 2008, 02:00:22 pm »
Ok, I started seriously messing with Anim8or few days ago and I keep failing to get the results I want. I've read bunch of tutorials, but each time I try to do something my way, I'm stuck.
This is the basic outline of a ship model I am trying to create and keep failing:
My problems. Faces division. I keep doing something wrong here. I don't know how to divide a face (on desired parts) and then extrude individual parts. Cut face tool is confusing me. For the front "guns" I had to create new solids, and as you see, when I apply convert to subdivied I get c**p. That's another problem. Smoothing control. Edge properties doesn't seem to work for me at all. I tryed everything. Even select all edges and play with the rounded ratio in edge properties. Nothing. I get same results each time after convert to subdivision.
Any help is appreciated. Here is the Anim8or file: http://www.ftpisland.com/lachie13/ship_testing.an8
If you can help me merge the "guns" with the ship and help me figure out the edges smooting, that would be great.
Help me!
« Last Edit: June 25, 2008, 02:12:45 pm by Lachie Dazdarian »
Lachie Dazdarian
Re: A newbie trying to model a space ship (help!)
« Reply #1 on: June 25, 2008, 03:45:28 pm »
Ok, I made a slight improvement. This time select all edges and rounded set to 1 worked. I must have been doing something wrong.
Although, this doesn't solve all my problems.
Mactetra
  • 𝕸𝖆𝖈𝖙𝖊𝖙𝖗𝖆
« Reply #2 on: June 25, 2008, 05:03:52 pm »
Here u go..
Hopes this solves your problem ;)
Mactetra
  • 𝕸𝖆𝖈𝖙𝖊𝖙𝖗𝖆
« Reply #3 on: June 25, 2008, 05:08:12 pm »
Oh.. the text was a bit blurred... here it is:
1. Let's pretend this is your spaceship
2. Select theese two faces, the ones you whant to link together, and click: Edit > bridge
3. This will be the result:
4. Do the same for the second one
5. Now click your object, then click: Build > subdivide faces. and fill inn the value like this:
6. Do the same as in step 5 once more, then click: Build > convert to subdivided. You will end up with this:
7. Hope this helps! Happy anim8ing! Mac.T
Lachie Dazdarian
« Reply #4 on: June 25, 2008, 06:16:28 pm »
Thanks. This helped a lot.
I shouldn't complain on the tutorials I read / watched as they are great, but over 5 I read missed some of these important features. Maybe a tutorial completely oriented on creating a really complex object with extrusions and what not would be nice. Hopefully I won't need it.
EDIT:
Wait. Forgot to ask. How did you split the front main body face in two parts? I'm having difficulties using the cut tool.
« Last Edit: June 25, 2008, 06:42:23 pm by Lachie Dazdarian »
Mactetra
  • 𝕸𝖆𝖈𝖙𝖊𝖙𝖗𝖆
« Reply #5 on: June 25, 2008, 07:51:14 pm »
just used the knife thingy.. and dragged a line down...
