Author Topic: Animation crashing  (Read 9661 times)
Gregory
Animation crashing
« on: June 21, 2008, 10:49:48 pm »
I have a simple scene:
One object flying along a path.  One infinite light.  One camera.
Scanline renderer, .bmp output.  Nvidia GeForce 7600 GS
When the light is set to cast volume shadows, the scene animation renders.  When I set it to raytrace, ordered or monte carlo, it renders a few frames and crashes.  This happens in 095 and 097.  During any kind of rendering, still or movie, my monitor randomly goes black, and even off throughout the process.
It has been a couple of years since I rendered animations but never had this trouble with anim8or before.  Can anyone help please.
Edit:
Just tested again:  it renders 7 frames then crashes.  I render the next set and again, seven frames then crash.
« Last Edit: June 21, 2008, 11:42:23 pm by Gregory »
Re: Animation crashing
« Reply #1 on: June 22, 2008, 01:15:06 am »
What video compressor are you using?  Sometimes they don't work properly and crash anim8or.  So I'd try a different one.
Gregory
« Reply #2 on: June 22, 2008, 01:28:04 am »
I wrote that output is to bitmap.
I've now tried this in version .09 .095  and .097 -  same result -- always crashes after 7 frames and throws the error:
Microsoft Visual C++ Library
then the animator path
Edit:
I've installed new graphics drivers from Nvidia and it seems to be working fine now.
« Last Edit: June 22, 2008, 01:54:39 am by Gregory »
karate5662
    • my mini city
« Reply #3 on: June 22, 2008, 08:36:09 am »
what hihosilver means is what video codec you are using to compress you video, microsoft video 1, no compression, ect.
mcheccyb
« Reply #4 on: June 22, 2008, 04:26:23 pm »
i think he is exporting each frame as an individual .bmp image.
Gregory
« Reply #5 on: June 22, 2008, 06:15:41 pm »
Correct.
« Reply #6 on: June 23, 2008, 04:52:52 am »
(Sarcastically) What gave that away, that fact that he said so on his post?
But, yeah, I've had that problem as well, maybe Steve will have to look into it (if he isn't already)
The raytracer is still a bit unstable :(
