Author Topic: How to get full texture filename?  (Read 12898 times)
Jolly Roger
« on: June 09, 2008, 02:56:20 pm »
The example c export plugin script writes the name of the texture to file but don't include it's extension (jpg, gif, bmp).
How would I go about getting the full filename of a texture?
Thanks.
Roger
« Last Edit: June 09, 2008, 03:12:59 pm by Jolly Roger »
Re: How to get full texture filename?
« Reply #1 on: June 09, 2008, 09:09:45 pm »
From the script spec:
Texture Type
struct texture {
    string name;       // texture’s name
    int Marked;        // Marked flag, 1 or 0
    const int CubeMap; // 1 if a Cube Map, else 0
    int InvertImage;   // invert image flag, 1 or 0
    string GetFileName(void);
    string GetCubeMapFileName(int face);
    int SetFileName(string name);
    int SetCubeMapFileName(string name, int face);
He's probably using the name member.
Try the "string GetFileName(void)" one.You should get the extension
and the directory also if my memory doesn't fail me.
« Reply #2 on: June 10, 2008, 01:13:20 am »
That's correct.  The name field is the testure's name as used within Anim8or.  The GetFileName() function returns the file name.
Jolly Roger
« Reply #3 on: June 10, 2008, 04:11:36 pm »
Thanks for your help.
Roger
Jolly Roger
« Reply #4 on: June 11, 2008, 02:57:51 pm »
I've tried tinkering with the code but I can't seem to get it to work. Although I'm no stranger to programming I know next to nothing about c.
I'd be grateful for a snippet of code to show me how to do this.
Thanks.
Roger
Jolly Roger
« Reply #5 on: June 12, 2008, 07:26:53 pm »
I've finally worked it out.  :)
This seems to do the trick:
$name[1] = $tex[1].GetFileName();
$name[2] = $tex[1].name +"."+$name[1].GetExt;
$output.print("TextureFilename {\n");
$output.print("\"%s\";\n", $name[2]);
