Author Topic: List of lip synchs  (Read 5663 times)
flametiger74
List of lip synchs
« on: June 01, 2008, 10:56:45 pm »
I remember a while back of someone posting a link to a page with all the letters and sounds a mouth can make with pictures of what the mouth would look like at that point. I want to try to start some lip-syching but I need some point of reference. Thanks.
Re: List of lip synchs
« Reply #1 on: June 01, 2008, 11:47:45 pm »
The "mouth positions" are called phonemes.  They are the smallest unit of sound basically.
Here's a very useful image (you can find more on google images, which is where I found this):
One thing I've learned about lip syncing is that it's always best to exaggerate your morph targets a good deal.  Then, you don't have to set the morph to 1, you can set it to something like .5 if needed.  If you don't exaggerate though, and you want an exaggerated mouth pose and try to set the morph to something like 1.5 or 2, you have a much higher possibility of it becoming deformed.  Just a little tip there.
Remember as well, the acting isn't entirely in the mouth.  To give a character real expression, you really need eye and eyebrow expression.
Good luck.
