Author Topic: Edge properties  (Read 14683 times)
Roygee
  • Carpa diem
Edge properties
« on: January 06, 2008, 04:46:47 pm »
The model I'm making needs to be mostly smoothed, but parts to stay hard and sharp - I normally use edge re-enforcement, by cutting through close to the edge and this works fine, but in this model that method would be way too complex and really messy.  I tried using edge properties, with a setting of creased, value 2, but when I convert to subdivided
(just a single subdivision), there is no difference - everything is rounded.
What sort of settings should I be using? ???
Re: Edge properties
« Reply #1 on: January 06, 2008, 05:13:35 pm »
To set how the edge will look after subdivision you must use "rounded" value.
http://www.anim8or.com/manual/4_object_editor.html#edge_editing
Dasoccerguy
Re: Edge properties
« Reply #2 on: January 06, 2008, 10:56:02 pm »
i find that sometimes bevelling certain edges can give that effect, but it might be just as messy as reinforcing the edges...
hope you find your answer
Re: Edge properties
« Reply #3 on: January 07, 2008, 01:04:10 am »
Dasoccerguy:  Beveling edges is a way of edge reinforcement.
