Hi all!
I'm new to Anim8or, but I have looked in the manual and searched this forum and the internet for a solution to my problem.
I need to make a letter, convert it to a spline and then edit it (adding/removing points). This I can do, but it seems that I cannot edit all of it. For example in an "O", I can edit the outher spline but not the inner. I can move the points around in the inner, but I cannot delete points. The splines seems to be related in some way, but is it possible to convert textsplines into "simple, independent" splines?
When I've done editing the text, I want to lathe it, and that's why I need splines. Otherwise I guess I could convert it to a mesh.
Thanks in advance,
Nightwing
