Author Topic: Editing text splines  (Read 6751 times)
Nightwing
« on: May 20, 2008, 06:56:23 am »
Hi all!
I'm new to Anim8or, but I have looked in the manual and searched this forum and the internet for a solution to my problem.
I need to make a letter, convert it to a spline and then edit it (adding/removing points). This I can do, but it seems that I cannot edit all of it. For example in an "O", I can edit the outher spline but not the inner. I can move the points around in the inner, but I cannot delete points. The splines seems to be related in some way, but is it possible to convert textsplines into "simple, independent" splines?
When I've done editing the text, I want to lathe it, and that's why I need splines. Otherwise I guess I could convert it to a mesh.
Thanks in advance,
Nightwing
jacko
Re: Editing text splines
« Reply #1 on: May 20, 2008, 07:56:31 am »
Try to ungroup them.
Nightwing
« Reply #2 on: May 20, 2008, 08:12:35 am »
I've tried that! I need to ungroup anyway when making the text into splines before being able to edit them.
/Nightwing
jacko
« Reply #3 on: May 20, 2008, 08:26:26 am »
 I tested by >One text< ->Build Extrude -> Convert to Mesh -> Ungroup there was no problems to edit or delete points.
Nightwing
« Reply #4 on: May 20, 2008, 08:36:22 am »
Yes, but the problem is (as I wrote in the original post) that I want to lathe it ... and you can only do that with splines.
