Author Topic: Is there a way to insert extra time in a scene?  (Read 6560 times)
flametiger74
« on: May 18, 2008, 11:31:48 pm »
Is it possible to insert time between two keys in scene mode.
Basically what happened is I had a scene where you see a guy walk in and sit down. Now I want to show the room around a bit before he walks in. To do that I would have to add extra time at the beginning of the scene. To add time would be a tedious job of making the scene time longer, copying and pasting all the keys, and making sure they were pasted correctly and evenly.
Does anyone know of any way that I could do that.
If this isn't a feature yet, I would recommend it would be a little handy tool.
mak
Re: Is there a way to insert extra time in a scene?
« Reply #1 on: May 18, 2008, 11:42:26 pm »
goto the frame inbeetween then Edit> frames>
realisim is for reality
« Reply #2 on: May 19, 2008, 02:03:31 am »
Or, you could select all the frames that you want to move (you probably want to extend the scene length first,) then copy "ctrl +c" and go to a much later frame (make sure you have enough frames after that frame to paste it all,) and paste it! "ctrl + v"
