Author Topic: silly question from a newbie  (Read 6126 times)
auto78900
« on: May 07, 2008, 10:25:13 pm »
I have the egg plant tutorial loaded into the program, but I can not see a "go" or "run" sequence ?
where do I click to see the animation running ?
Re: silly question from a newbie
« Reply #1 on: May 07, 2008, 11:22:16 pm »
There is no animation for the eggplant tutorial.  There are four different objects that you can go to which are stages in the actual tutorial.  You can view the different objects from Object mode by going "Object>" then pick the object you want to view.  The file is only meant to show you what you should be achieving along the way.  The actual tutorial is the text on the website.
auto78900
« Reply #2 on: May 07, 2008, 11:35:25 pm »
Thank you for your reply, what was the "Simple Texture mapping tutorial" suppose to do ?
its a torso ? but the tutorial is not on geocities anymore.
I want to draw either an animal or human and just have it slowly spin as a 3D video clip.
are there any simple examples of this ?
