Author Topic: Help with bone axis in sequence mode  (Read 7643 times)
6riku6
« on: May 04, 2008, 07:30:58 am »
Ok i am having a slight problem in sequence mode!
I have skined the model to bones and that all works fine and i have set axis but what i cant get my head around is that when i rotate the bone across the Z axis the X axis does not rotate making it impossible to move the arm back and forth for a walk cycle!
Any help would be aprecciated pictures below!
Thanks in advance!
Re: Help with bone axis in sequence mode
« Reply #1 on: May 05, 2008, 06:13:13 am »
You can move the different axis with the different mouse keys. Click on the bone you want to move and lock/unlock the axis. Then ones locked cant be moved around, the ones unlocked can. So if you want to move you bone around the X-axis, click on the bone and lock the Y,Z-axis and unlock the X-axis.
