Author Topic: Drawing Lines  (Read 22736 times)
Simon
    • Simon's Simple Site
Drawing Lines
« on: January 04, 2008, 08:31:17 pm »
I was wondering,
Is it possible to draw lines using ASL?
If so,
After drawing say, 5 and they are connected can you fill in the surface?
Nate_Bro
    • Set Apart Graphics
Re: Drawing Lines
« Reply #1 on: January 05, 2008, 01:04:06 am »
I belive you would have to set the points, then create the faces.
if you want just a line, you can create the points then create edges, but if you want faces, just points and faces should work fine.
My computer specs for Anim8or and other graphics:
1.  3.2 GHz Pent 4 HT 1 MB L2, with ATI 128 MB Vid Card
2.  3.0 GHz Pent D 4 MB L2, with ATI 512 MB Vid Card
3.  1.7 GHz Pent Celeron M, with ATI 64 MB Vid Card
Simon
Re: Drawing Lines
« Reply #2 on: January 10, 2008, 09:57:36 pm »
Ok that works...
Now, if I wanted to select points and then click a button.
How do I find out which points are selected?
Claude
Re: Drawing Lines
« Reply #3 on: January 11, 2008, 12:16:22 am »
Here's an example not including the variable declaration and initialization:
Code: [Select]
             /* Lets search for the selected point */
              for $ii = 0 to $numPoints - 1 do
                 if ($mdata.GetPointSelected($ii) == 1  )
                   /* Do whatever you want if the point is selected */
Simon
Re: Drawing Lines
« Reply #4 on: January 13, 2008, 07:31:25 pm »
Thanks, That is exactly what I needed.
