Author Topic: gennemsigtig så det liner farvet glas.  (Read 12411 times)
DisDus
« on: April 24, 2008, 02:46:52 pm »
Hej med jer her på Anim8or Community. Jeg er en Dansker som er begyndt at arbejde i Anim8or.
Er der nogen her i dette Forum der kan fortælle mig hvordan man gør sine genstande i Anim8or gennemsigtig så det liner farvet glas.
Mange Hilsner DisDus ;)
dajean
  • Creativity
Re: gennemsigtig så det liner farvet glas.
« Reply #1 on: April 24, 2008, 03:01:19 pm »
I don't  think anyone is gonna be able to help you unless you explain your issue in engllish ;)
« Reply #2 on: April 24, 2008, 05:45:58 pm »
In material editor set
Rough : 70
Brilliance : 1.5
Trans : 0.10
Også, læse den manual for nærmere oplysninger.
http://www.anim8or.com/manual/index.html
CydoniaKnight
« Reply #3 on: April 25, 2008, 12:51:14 am »
I don't think he will understand anything that you just said! :)
« Reply #4 on: April 25, 2008, 03:25:39 am »
Lynn, what language was that, German?
« Reply #5 on: April 25, 2008, 05:16:57 am »
I belief its danish, or an other scandinavian language. And i belief he asks how to make a glass material.
Glass: Use an env. map on 25 or use ART raytraced reflections (anim8or v0.97) and set the transperancy to 0,2 - 0,4.
« Reply #6 on: April 25, 2008, 06:27:01 am »
Tanzim, the language is Danish and he asked how to make glass
Floyd86, just a question, why do you use an env. map to make glass ?
« Reply #7 on: April 25, 2008, 01:10:13 pm »
An environment map gives your material a fake reflection. Because glass is never 100% transparent and always reflects light. When you apply an environment map to the material it will look more 'real'. Also look at the manual for this: http://anim8or.com/manual/10_materials.html.
falloffalot
« Reply #8 on: April 25, 2008, 04:55:15 pm »
Well done Lynn22
PS: cool web site BtW 8), was unable to post any response though.  ???
« Reply #9 on: April 25, 2008, 05:46:55 pm »
Thanks Floyd86, it was only a few hours after posting the question that the answer dawned on me ... because of the reflection.
Thanks falloffalot, much appreciated and thanks for pointing out the problem of posting a message. I wrote a little script to stop spammer bots from posting but I realize now that the rules are a bit too tight. I'll quickly change that   ;)
Edit : messages are working again  ;D
« Last Edit: April 25, 2008, 06:10:57 pm by lynn22 »
RnDr FOX
  • Just Relax
« Reply #10 on: April 28, 2008, 09:01:14 pm »
What website are you talking about
« Reply #11 on: April 29, 2008, 03:54:01 am »
RnDr FOX, we're talking about  my anim8or site. The link is in my profile  :D
