Author Topic: Rotating object in once positon??  (Read 7835 times)
D.J
« on: April 22, 2008, 01:21:06 am »
Hey everyone, Im fairly new to Anim8or and have to my sense a good hang of the program, so glad I downloaded it..
Anyways, I wanted to know if there is a way I could rotate an object in one position over and over again in a sequence. Like hellicopter blades spinning or propellers or wheels, get my flow? All I know how to do is make a skeleton and animate the bones on them, but when I want to make something rotate in place, it just moves in a full circle as if in an orbit, instead of staying in a position and rotating.
almost cool
  • The Truffle Shuffle
    • www.deadboltdevelopment.com
Re: Rotating object in once positon??
« Reply #1 on: April 22, 2008, 01:26:35 am »
Ty using a differint axis.Which are you using?
D.J
« Reply #2 on: April 22, 2008, 01:34:46 am »
Ive tried all three =\
« Reply #3 on: April 22, 2008, 01:35:47 am »
Remember about pivot points as well.  You want the pivot point of the bone in the center of the object.  Still, there's a better way to do this, and that's with scripts.  You can find a good rotational script Here.
almost cool
« Reply #4 on: April 22, 2008, 01:42:25 am »
Do you mean like the rotational value of a wheel?
D.J
« Reply #5 on: April 22, 2008, 01:52:33 am »
Thanks I'll give that a try and see if it works. And "Almost Cool," yes, like the rotation of a wheel
