Author Topic: How do i make path into a wire shape  (Read 13129 times)
Wowsie
« on: May 26, 2024, 06:30:59 am »
how do i turn paths into a wire shape
example:
NickE
Re: How do i make path into a wire shape
« Reply #1 on: May 30, 2024, 06:36:41 am »
There is a script called spline.txt that Steve wrote.  There is also a parameterized version called spline_tube.a8s.  Search the forum for them.
« Last Edit: May 30, 2024, 06:39:18 am by NickE »
raindrop
« Reply #2 on: June 09, 2024, 12:32:13 am »
After making a curve make a shape by using build > primitives > N-gon then use add N-gon tool in shapes section. Now select that shape then go to build > extrude and choose along a path option. After confirming the dialog you need to click on the curve you created first. Now there will be tube. ;)
