Author Topic: Undoing Changes in the Scene Editor  (Read 5895 times)
moodyblues
« on: April 21, 2008, 01:55:11 am »
Hi, everyone!  I started using Anim8tor a few days ago, and it's lots of fun so far.  However, I'm having a problem in the scene editor.  When I move objects, such as the camera or light sources, I can't use undo.  The text on the bottom-left corner reports what I'm trying to undo or redo - "Undo rotate," for example - but nothing in the scene actually goes back to the way it was, even if I don't switch between modes.  The entire file is only 28.8 KB, so I don't think it's because the model is too complex for the undo queue to handle.
If anyone could help me with this, I'd appreciate it.
« Last Edit: April 21, 2008, 01:58:36 am by moodyblues »
Claude
Re: Undoing Changes in the Scene Editor
« Reply #1 on: April 21, 2008, 09:59:07 am »
Menu File/Configure. Check the size of the undo buffer.
« Reply #2 on: April 21, 2008, 01:23:17 pm »
For some reason, if not using keyframes, you can't undo your positioning in scene mode.  It will undo adding elements, but not rotations and movement unless you're keyframing the rotation/movement.
