Author Topic: Array copy or similar?  (Read 11979 times)
AlecJames
« on: May 01, 2023, 03:54:41 pm »
I want to model a ball covered in lights.  A large sphere with smaller spheres placed at the large sphere vertexes will be fine.
Is there any method or script that can copy an object multiple times to create a ring of objects?  Or other ways to create the sphere covered in small spheres?  I want to make many, so doing it manually might take a while.
Thanks
NickE
Re: Array copy or similar?
« Reply #1 on: May 02, 2023, 06:25:41 am »
Alec,
In the scripts section, there are two scripts that might be applicable: mesh2mesh and mesh2path.  mesh2mesh copies an mesh to the vertices of another mesh while mesh2path copies a mesh along a path.  Search the posts as there are decent writeups on each in scripting section.
NickE
AlecJames
« Reply #2 on: May 02, 2023, 11:34:07 am »
Thanks NickE, just what I needed
« Last Edit: May 02, 2023, 11:34:58 am by AlecJames »
NickE
« Reply #3 on: May 02, 2023, 08:34:33 pm »
You are welcome!  Looking forward to seeing what more you do with it!
AlecJames
« Reply #4 on: May 26, 2023, 01:58:13 pm »
Wedding anniversary video in production for my daughter - based on Disney's main street electrical parade and starring her dog.  I'm some weeks away from the first draft.
I'm using the mesh2mesh for "thousands of sparkling lights".  :)
