Author Topic: Feature request: Several uv coords per vertex  (Read 8485 times)
texel
« on: April 17, 2008, 09:35:40 am »
hi,
it would be great and very usefull to be able to have several uv coordinates per vertex in order to have:
_ 1 uv coord for the diffuse texture
_ 1 uv coord for bumpmap texture
_ 1 uv coord for speculare
_ ...
Re: Feature request: Several uv coords per vertex
« Reply #1 on: April 17, 2008, 09:43:06 am »
Seconded! Multiple UV channels would be excellent, but if this were to be implemented, the ability to import/export UVs should also be added!
« Reply #2 on: April 18, 2008, 06:02:55 am »
So long as it was not actually necessary to set the coordinate for each separate level every time.  The default should still be coincident UV coords, able to be separated as a choice.  But yeah, great idea.
texel
« Reply #3 on: April 18, 2008, 08:15:58 am »
with the ability to switch the uv channel between diffuse, ambient, bumpmap, custom, ... to keep it flexible
