Author Topic: Help Texturing?  (Read 13073 times)
Syphon
Help Texturing?
« on: January 03, 2008, 02:50:53 am »
First, I make my texture, then it turns out to be too small for model with UV Mapping... How do you know how big you have to make? Can I just scale the model down and the texture will stay the same?
Second, sometimes when I try to load a texture it says File Failed to Load, what causes that?
Re: Help Texturing?
« Reply #1 on: January 03, 2008, 10:58:30 pm »
i've had that problem as well but only with bitmaps, try using jpegs instead
for the small texture problem try scaling it up abit, using the middle mouse button
Syphon
Re: Help Texturing?
« Reply #2 on: January 03, 2008, 11:23:38 pm »
I got all of that working, but now I'm having problems with rendering my final images...
I need to render 17 different views of the same model, from a slightly less the isometric view, but I can't figure out to change the view... Neatly, dragging with the mouse is sloppy, is there another way?
