Author Topic: it works!!  (Read 11617 times)
Kevin Gales
it works!!
« on: April 06, 2021, 06:28:50 pm »
Finally I got 3 months break I can get back to anim8or...Anyway I'll be working on a talking head I want to make it as best as it can get with anim8or.
So while I was working (doing some coding and stuff for a company) I found a solution to one other thing that fascinated me...I wanted to export blender to anim8or and I did...Below is the fifth test of porting ripples animation made with blender 2.82 physics to anim8or morph targets and yeah it worked 100%  8)
Re: it works!!
« Reply #1 on: April 07, 2021, 11:12:04 am »
Looks good.
Kevin Gales
Re: it works!!
« Reply #2 on: April 07, 2021, 01:13:05 pm »
I know right   :D I am still cleaning up the code...so I can make it simple for everyone to use... so I'll share when I am done...in case there are people interested
Claude
Re: it works!!
« Reply #3 on: April 07, 2021, 02:01:33 pm »
Are you writing a Blender export plugin ?
Kevin Gales
Re: it works!!
« Reply #4 on: April 07, 2021, 02:43:22 pm »
I am coding a standalone software in which a user can just load a blend and click just once then voila...everything should be done...
I am going to use the same style I used for "nifty tool" I posted under ASL scripts
Kevin Gales
Re: it works!!
« Reply #5 on: July 29, 2021, 04:11:31 pm »
I am back...I ran into problems when I tried to directly link the coding with blender so I decided to take a different approach...So I instead made the tool to upload multiple objects and convert them to anim8or morph target...So basically I can still export blender animation and convert it to anim8or animation in just one click...
The interesting part is that in anim8or the object can still be modified in point mode and subdivided even the morph target can be controlled and re animated just like in the video above
Anyway here is the link to the tool with some other features the one described above is the last on the list...
Nifty tool on anim8or
« Last Edit: July 29, 2021, 04:14:25 pm by Kevin Gales »
