Author Topic: Controller disappears from scene time track  (Read 35158 times)
AlecJames
« on: August 05, 2020, 06:03:22 am »
On build 1387 (and others)
Hi Steve,  I've found a minor issue.  Create figure with 1 bone, add to a scene, create a key on bone-y,  double click the key and delete it from the dialog, the controller disappears.  Closing and re-opening the project restores it.
AlecJames
Re: Controller disappears from scene time track
« Reply #1 on: August 05, 2020, 10:57:52 am »
While I'm being picky :)
Same figure with an expression on the bone Y orientation but no other keys in the scene - the expression(s) are not saved, the first time I found this I lost the figure from the scene as well, when I try to re-create I just loose the expressions on the bones. If I add a position key it saves everything.
AlecJames
« Reply #2 on: August 05, 2020, 04:32:08 pm »
My second post - either I've forgotten something or this is more serious;  I can't save expressions to the anim8or file.
I've got a single multi-bone figure in my scene and I'm testing out expressions on the bone angles.  Every time I save close reopen, all the expressions are lost.  I went back to v1.00, same.  I went back to v0.98 and it saves the expressions OK.
« Reply #3 on: August 05, 2020, 06:17:41 pm »
Thanks, AlecJames, I'll definitely fix these problems!
#101-042 - Controller disappears when deleting only key from bone axis.
#101-043 - Bone axis expressions aren't saved to project file.
« Reply #4 on: August 09, 2020, 03:01:33 pm »
AlecJames can you try build 1390 to see if it fixes these problems? If not, I need an example (simple if possible :) )that I can debug.
Thanks!
AlecJames
« Reply #5 on: August 11, 2020, 04:34:48 am »
Hi Steve,
I made a demo video showing the problems:
Thanks for the hard work :)
« Last Edit: August 11, 2020, 02:17:52 pm by AlecJames »
« Reply #6 on: August 11, 2020, 12:40:16 pm »
AlecJames: Oops! The video is private so I can't view it...
AlecJames
« Reply #7 on: August 11, 2020, 02:18:22 pm »
This is why my channel has no followers :) :)
Should be OK now
« Last Edit: August 11, 2020, 02:18:58 pm by AlecJames »
« Reply #8 on: August 11, 2020, 07:14:09 pm »
Don't know what I was doing before but I can reproduce both issues following your example. I'll have this fixed as soon as I can!
Thanks for the bug report!!!!
« Reply #9 on: August 11, 2020, 07:46:41 pm »
This is definitely a bug but it's been in Anim8or for a while. If you do this in Rotate Bone mode then it works properly. Clicking on a bone opens the X-axis controller and when you're done there are controllers for all 3 axis with a script for the X-axiz. But if you click on the time track to add the script controller, then it's not saved.
I was adding the controller the way it works and so couldn't see the issue.
Stay tuned ... work in progress :)
« Reply #10 on: August 12, 2020, 01:13:14 pm »
AlecJames give build 1391 a try when you get a chance. I think it fixes both of these issues.
AlecJames
« Reply #11 on: August 13, 2020, 03:33:39 am »
Thanks Steve - this looks good to me :)
AlecJames
« Reply #12 on: August 15, 2020, 04:40:29 am »
Hi Steve, just went back to this and found that when I assign an expression to a bone, save the file, close and reopen, the controller is no longer shown so I can't edit the expression.  Is there another way to get to it?
« Last Edit: August 20, 2020, 05:11:13 am by AlecJames »
AlecJames
« Reply #13 on: August 15, 2020, 04:44:01 pm »
My bad - I found it, bone1-Z is at the and of the list (I was looking for it near bone1-x bone1-y)
« Reply #14 on: August 16, 2020, 09:05:43 am »
Yes, for some reason the scripts cause the bones to be out of order. I'm looking into how to fix this.
