Author Topic: Fast 3D Export (Beta) 0625  (Read 15299 times)
Trevor
    • LS Tech Services
« on: May 10, 2020, 12:13:00 pm »
Here is an export plugin for Fast3D at source level.
Debug mode is enabled
ver 20200625 (Beta)
  Features:
  • Duplicate Vertex removal
  • Triangle Sorting
  • Flat Shading
  • Smooth Shading (Lighting only, An8 does not support Vertex Shading)
  • Lighting
  • Fog (Disables Vertex Alpha as N64 places Distance on Vertex Alpha)
  • Texture Mapping
  • Environment Mapping
  • Bounding Box
  • Bounding Volume Radius - Nothing Output Yet
  • Binary Seperating Plane (Partial Support with Tree traversal)
  • Groups and full hiearchy. Usefull for animation or part culling.   [/color]
  Supports:
  • Fast3D (16 vertex cache)(Default)
  • 4Tri   (GE/PD Fast3D Extension)
  • F3DEX  (32 Vertex Cache, 2Triangles)
  • F3DEX2 (32 Vertex Cache, 2Triangles)
  WishList:
  Portals (use mesh name "PortalA-B")
  Animations - Translate/Rotate
                        Needs flag IsAnimate else Pre-Calc matrix
                        using $point = $transformMat.Project($point);
  Attributes (Case in-sensitive):
    uCode    - Define EITHER a String Attribute with name "uCode" with:
                                             OR
                            Define an Attribute of ANY type with name:
                              Fast3D (default)
                              F3DEX
                              F3DEX2
    4 Triangles Extension - Define an Attribute of ANY type with name "TRI4_Ext"
    Vertex Cache Override - Define an Integer with name "VtxCacheOvr" (Not Recomended)
    Integer Vertices         - Define a Boolean with name "IntVtx" (Default False)
    Optimization Level    - Define an Integer with name "Optimize"
                                       0 None
                                       1 Sort Triangles
                                       2 Trim Duplicate Vertices  (Default)
                                       3 Trim Vertices Aggressive (Not Recomended)
                                                   Ignore ST and RGBA, Force Integer Vertices
    Lighting              - Define a Boolean with name "G_LIGHTING" (Default false)
    Fog                      - Define a Boolean with name "G_FOG" (Default True)
    Auto Sun (Static      - Define a Point with name "AutoSun" (Default False)
          Vertex Shading)  X = Direction(0-360) (North = 0, East = 90 etc)
                                       Y = Azimuth (0-90) where 0 is the Horizon
Code: [Select]
  *   Ortho View
 *               90 Y+. Azimuth
 *                    |  S  180
 *             E 90   |  /
 *         0 .  /`                  ``--:.`.
 *           ./`                       :----' X+ W 270
 *    Z+ ````` N 0
  Light direction is "Source" of light
    eg: The sun is in the south (180) at 45 High
Result C attached as txt
H
Code: [Select]
* Export object "object01"
* Do not edit this file. It was automatically generated
* with Anim8or 1.01 Build 1.01.1378+
* from File "test.an8"
* Using uCode Fast3D
#define G_CC_PASS1 0, 0, 0, 0, 0, 0, 0, 0
#define G_CC_PRIMSHADE PRIMITIVE, 0, SHADE, 0, 0, 0, 0, 1
#define G_CC_PRIMSHADEA PRIMITIVE, 0, SHADE, 0, 0, 0, 0, SHADE
#define G_CC_PRIMSHADEFA PRIMITIVE, 0, SHADE, 0, 0, 0, 0, PRIMITIVE
#define G_CC_SHADE2 PRIMITIVE, 0, SHADE, 0, 0, 0, 0, 1
#define G_CC_SHADE2A PRIMITIVE, 0, SHADE, 0, 0, 0, 0, SHADE
#define G_CC_SHADE2FA PRIMITIVE, 0, SHADE, 0, 0, 0, 0, PRIMITIVE
#define G_CC_MODRGB COMBINED, 0, SHADE, 0, 0, 0, 0, 1
#define G_CC_MODRGBA  COMBINED, 0, SHADE, 0, 0, 0, 0, SHADE
#define G_CC_MODRGBFA COMBINED, 0, SHADE, 0, 0, 0, 0, PRIMITIVE
#define LoadTextureBlock(ltbTextureName, ltbTextureImageFormat, ltbBitDepth, isDetail, width,    \
                         height, pal, cms, cmt, masks, maskt, shifts, shiftt)                    \
        gsDPSetTextureImage(ltbTextureImageFormat, ltbBitDepth##_LOAD_BLOCK, 1, ltbTextureName), \
        gsDPSetTile(ltbTextureImageFormat, ltbBitDepth##_LOAD_BLOCK, 0, 0, G_TX_LOADTILE,        \
                    0 , cmt, maskt,    shiftt, cms, masks, shifts),                              \
        gsDPLoadSync(),        \
        gsDPLoadBlock(G_TX_LOADTILE, 0, 0,                                                       \
                    (((width)*(height) + ltbBitDepth##_INCR) >> ltbBitDepth##_SHIFT)-1,          \
                    CALC_DXT(width, ltbBitDepth##_BYTES)),                                       \
        gsDPPipeSync(),        \
        gsDPSetTile(ltbTextureImageFormat, ltbBitDepth,                                          \
                    ((((width) * ltbBitDepth##_LINE_BYTES)+7)>>3), 0,                            \
                    G_TX_RENDERTILE+isDetail, pal, cmt, maskt, shiftt, cms, masks, shifts),      \
        gsDPSetTileltbBitDepthe(G_TX_RENDERTILE+isDetail, 0, 0,                                  \
                    ((width)-1) << G_TEXTURE_IMAGE_FRAC,                                         \
                    ((height)-1) << G_TEXTURE_IMAGE_FRAC)
#define LoadMipMapTile(tmemoffset, rtile, ltbTextureImageFormat, ltbBitDepth, width,             \
                    ((((width) * ltbBitDepth##_LINE_BYTES)+7)>>3), tmemoffset,                   \
                    rtile, pal, cmt, maskt, shiftt, cms, masks, shifts),                         \
        gsDPSetTileltbBitDepthe(rtile, 0, 0,                                                     \
/* Define Textures */
 * Texture image format :
 *     G_IM_FMT_RGBA(RGBA format)
 *     G_IM_FMT_YUV (YUV format)
 *     G_IM_FMT_CI  (CI format)
 *     G_IM_FMT_IA  (IA format)
 *     G_IM_FMT_I   (I format)
 * Bit Depth :
 *     G_IM_SIZ_8b  (8 bits / texel)
 *     G_IM_SIZ_16b (16 bits / texel)
 *     G_IM_SIZ_32b (32 bits / texel)
 * S T Flags :
 *     G_TX_MIRROR  (enable mirror operations)
 *     G_TX_NOMIRROR(disable mirror operations)
 *     G_TX_WRAP    (enable wrap operations)
 *     G_TX_CLAMP   (enable clamp operations)
/* Assign the corect values for brickdetail4colour Including any Mip-Map Tiles at end. */
#define BRICKDETAIL4COLOUR_Width  32
#define BRICKDETAIL4COLOUR_Height 32
#define BRICKDETAIL4COLOUR_MaskS  Log(BRICKDETAIL4COLOUR_Width) / Log(2)
#define BRICKDETAIL4COLOUR_MaskT  Log(BRICKDETAIL4COLOUR_Height) / Log(2)
#define BRICKDETAIL4COLOUR_DL \
    gsDPPipeSync(),        \
    LoadTextureBlock(&brickdetail4colour,        \
                     G_IM_FMT_RGBA, G_IM_SIZ_32b, FALSE, /* Format, BitDepth, isDetail */                            \
                     BRICKDETAIL4COLOUR_Width, BRICKDETAIL4COLOUR_Height, 0,      /* Width, Height, PaletteID   */                                   \
                     S Flags, T Flags,            /* Clamp/Wrap/Mirror          */                                   \
                     BRICKDETAIL4COLOUR_MaskS, BRICKDETAIL4COLOUR_MaskT,          /* Pow 2 Bounds for flag, eg  use 5 for a 32x32 texture (5^2=32) */\
                     ShiftS, ShiftT),             /* Use G_TX_NOLOD             */                                   \
    LoadMipMapTile(0, 0,                          /* TMEM Offset, TileNumber    */                                   \
                     G_IM_FMT_RGBA, G_IM_SIZ_32b, /* Format, BitDepth           */                                   \
  /* (From here, do LoadMipMapTile for each subsequent tile, eg a 32x32 usually has 6 tiles (0-5))                 */\
Trev
Edit 21:34, Added more draw commands
Edit 02:36, Added Triangle sorting, Auto Sun Baking, some other flags.
Edit 02:08, Added 4Tri and fixed VtxCache to batch by TnL changes and uCode limits (16/32 counts)
Edit 01:17, Added Tree traversal, Bounding boxes and named BSP support
« Last Edit: June 25, 2020, 08:31:27 pm by Trevor »
