Author Topic: Small bug on plugins  (Read 9706 times)
gzs
« on: April 14, 2008, 11:49:44 pm »
Hi folks,
I think I've found a bug when using parametric meshs plugins: if one figure is built using a parametric mesh, then when you open the anim8or file and go to scene mode WITHOUT first visiting the objects that are parametrics AND are used in figures, the scene editor refuses to build the parametric meshs whit this message (using the four wall plug-in):
Parametric  plug-in:
four wall
failed to return a mesh used to build:
four wall01
In old anim8or versions, the message also appears in the DOS window:
Executing script "I:\Anim8or\Scripts\4wall.a8s":
error on line 47: 'shape.Open()' command encountered when not in object mode
error in script - execution terminated.
Re: Small bug on plugins
« Reply #1 on: April 19, 2008, 04:41:50 pm »
Can you send me a .an8 project (and the pluig-in you're using) that shows this problem?  I definitely want to fix it.
gzs
« Reply #2 on: April 24, 2008, 08:13:34 pm »
Hi Steve,
I sent an email to rsteven@anim8or.com with the files.
Regards!
« Reply #3 on: May 07, 2008, 02:03:11 am »
Thanks, I got it and am looking at it now.
