Author Topic: Anim8or screen not working  (Read 6100 times)
brainerror
« on: December 10, 2019, 07:01:04 am »
Hello Anim8or Community. I'm having a problem with the program, has anyone had the same problem or know how to fix it?
Well, the program worked fine on my computer a while ago. But out of nowhere, one day when I opened it it was like this. I downloaded other versions (currently I have version 1.00) to see if it was back to normal, but all give the same problem, which is this screen there. If you click on the tabs above, such as "File", "Edit" and etc. It works normally, opens the tabs and allows you to click, but it does not give an image on the screen. I have tried also run it as administrator, and even run in compatibility mode with Windows XP and others, but nothing works.
If anyone can help me, thank you very much.  :'( :'( :'(
Kevin Gales
Re: Anim8or screen not working
« Reply #1 on: December 10, 2019, 12:10:26 pm »
Working with computers every time something like that happens it's usually 1.Low memory(Ram too small) 2.Low VRAM(graphic memory) you need to update your graphic card driver ALSO may be your graphic card is too old as in like supports ogl1.1 or older 3.Your graphic card is failing 4.OS too old to support your latest graphic drivers
Number 2 is common...it's possible anim8or cannot draw (open gl drawing) due to outdated ogl instruction
« Reply #2 on: December 10, 2019, 06:20:08 pm »
brainerror: Can you post the data from the About->SystemInfo dialog box?
brainerror
« Reply #3 on: December 11, 2019, 05:08:30 pm »
Ooooh, It must be this! Thank you so much for helping!! I'm so dumb!
Kevin Gales
« Reply #4 on: December 12, 2019, 11:49:05 am »
You're welcome  8)
