Author Topic: Help spherizing a mesh  (Read 7045 times)
steved
« on: October 06, 2019, 06:05:10 am »
Hello,
 I would really like some help running the Advanced Spherize script described in
 the thread: Advanced Spherize
 http://www.anim8or.com/smf/index.php/topic,4984.msg36541.html#msg36541
 The thread also contains the plugin and script file (Spherize.zip).
 I would really appreciate it if someone who's acquainted with this script would
 outline the steps required to spherize a mesh. A simple example would suffice.
 I create a mesh (lets say from a cube). I can run the parametric spherize helper
 shape successfully. But quite frankly I can never spherize a mesh because I
 simply don't understand the steps that are necessary after the helper shape is
 created. How exactly are the helper shape and mesh supposed to interact?
 What goes where?:) What is supposed to be selected and what is not.
 Are you supposed to do anything with the helper shape material that I see
 created? Thanks for any assistance you can offer.
 A baffled user,
 stephen
Re: Help spherizing a mesh
« Reply #1 on: October 14, 2019, 11:58:25 am »
Hi,
i create a simple video tutorial to you... (i post temporaly on StreamAble.com for first time) link below
https://streamable.com/yx50a
is how make the direct use, but you can Double click on "Circler Spherizing" to change some options...
steved
« Reply #2 on: October 17, 2019, 08:08:22 pm »
Hello neirao,
Sorry for the delay. I am just seeing your video now. Thanks to you the plugin is
now working exactly like your tutorial. When you know how to do something it appears ever so simple :)
I hope you can help me with one more thing regards to this plugin. I still cannot get
text to spherize. Perhaps you can just tell me the steps required to spherize a string of text.
Once again I am ever so grateful for your tutorial.
Best,
stephen
« Reply #3 on: October 18, 2019, 12:26:46 pm »
Hi Steve,
i will try do using text and after post here...
Tip: for work with "Texts" you need:
1-extrude the text(Build->extrude)
2-UNGRUP the text(Build-ungrup) if you not UNGROUP nothing works!!
another way... you can try use the "Modifiers"...
« Last Edit: October 18, 2019, 12:37:34 pm by neirao »
