Author Topic: Grassgen download  (Read 14696 times)
RnDr FOX
  • Just Relax
Grassgen download
« on: April 13, 2008, 09:51:05 pm »
Where can I download grassgen? I have tried every where but I cant find the download
CobraSpectre
Re: Grassgen download
« Reply #2 on: April 14, 2008, 11:59:10 am »
I'm fixing it to where http://mongoose.anim8or.org/ works again (was messed up due to some changes in site structure). It should be back up from a few minutes to a few hours, depending on where you live.
RnDr FOX
  • Just Relax
« Reply #3 on: April 14, 2008, 09:17:20 pm »
Thank you Raxx and Cobra
but
when I open up grassgen I get error the system file is not suitable for running MS-DOS and microsoft windows applications and then the program will end
« Last Edit: April 14, 2008, 10:43:50 pm by RnDr FOX »
« Reply #4 on: April 15, 2008, 06:58:40 am »
I have a problem working with grassgen. When i run a .ini file like the demo file it says: "Path not found in module GG1V20 at address 0DC1:00CD". Is there a way to fix this. I already tried running it in compatibility mode but same error.
RnDr FOX
  • Just Relax
« Reply #5 on: April 16, 2008, 10:44:41 pm »
Sorry had to bump the topic :-[
but can anyone help me with grassgen
« Reply #6 on: April 16, 2008, 11:28:52 pm »
Can you tell us what you're doing?  All I know is that you get an error.  That's a start, but I have no idea where to begin to address your problem.
« Reply #7 on: April 17, 2008, 05:51:22 am »
Starbuck already helps me with it, thanks.
mcheccyb
« Reply #8 on: April 17, 2008, 12:55:12 pm »
really, he didn't help me  :-[
RnDr FOX
  • Just Relax
« Reply #9 on: April 17, 2008, 09:49:49 pm »
Ok here is exactly what I do.
I put it in video format because I think that making a video would be easier than explaning
the link  http://two.xthost.info/RnDrFOX/
the video is called grassgen help
RnDr FOX
  • Just Relax
« Reply #10 on: April 20, 2008, 09:24:16 am »
Sorry had to bump it again :-[
It still doesnt work on my computer (XP)
but it works on my grandma's(VISTA)
please help the video file will explain it all
« Reply #11 on: April 20, 2008, 10:30:36 am »
I got an other error but what worked for me was placeing the gg1v20 map directly on your hdd, so in you C:\\. Also your problem seems to be with the file: autoexec.nt. See if you can replace that file, it might be broken.
