Author Topic: Is batch renders possible?  (Read 6700 times)
jbskaggs
« on: December 26, 2018, 01:34:57 pm »
Hi again.
Is there a way to do this procedure thru script?: Or maybe there is a plugin?
I set my model to orthoscopic
render model, save to png
rotate model 45 degrees on y axis and save to name+=1 png
Until all 8 major views are saved 0,45,90,135,180,225,270,315
This would save each render in each direction for png sprite use in a 2.5 / isometric game.
Re: Is batch renders possible?
« Reply #1 on: December 26, 2018, 04:37:29 pm »
There is a basic render command in ASL but it's not really that useful. It also seems to be broken at the moment :(
I'll see if I can fix a quick fix, and possible improve it so that you can do something like this.
jbskaggs
« Reply #2 on: December 26, 2018, 07:07:51 pm »
That would be awesome sauce my man!
« Reply #3 on: December 27, 2018, 10:51:47 pm »
I just posted a build that fixes the crash when rendering an image using ASL. This is a quick pass as I'm going out of town for a couple of days.  There's more to come.
The new build is v1.01.1352, December 27, 2018: Build 1352
I don't have the documentation done, but here's an example ASL file with a little documentation. Hope this helps!
jbskaggs
« Reply #4 on: December 27, 2018, 11:00:53 pm »
I pray your safe on your journeys and thanks for looking into this for me!
