Author Topic: Terranim8or and Anim8or  (Read 11678 times)
mikeman118
« on: April 13, 2008, 10:53:00 am »
Hi,
I was built a terrain in Terranim8or, and then when I open it Anim8or, it looks much less detailed. I attached pictures of the two different softwares.  The first one is Terrainim8or, and the second is Anim8or.  They don't look too different when rendered as a picture, but when I render it as a movie it looks much less detailed and not as good.  Is there any way to fix this or is this just how it is? Thanks in advance.
mcheccyb
Re: Terranim8or and Anim8or
« Reply #1 on: April 13, 2008, 11:53:02 am »
are they both rendered with anti-aliasing?
mikeman118
« Reply #2 on: April 13, 2008, 02:10:33 pm »
I know that the Anim8or one is with anti-aliasing, however since Terranim8or is cannot render images I'm not sure. (I had to take a screen shot).
« Reply #3 on: April 13, 2008, 02:26:54 pm »
That means that the terranim8or version is not rendered with antialiasing.  Antialiasing will not be used in the viewport as that would slow down the viewing process a TON.  So if you want the terrain to look like it does in terranim8or you may just want to turn off antialiasing, but then the edges won't look so good.
mikeman118
« Reply #4 on: April 13, 2008, 02:44:08 pm »
How do I do that?  ???
I can't check or uncheck anti-aliasing in the viewport preferences.
« Last Edit: April 13, 2008, 03:30:03 pm by mikeman118 »
mikeman118
« Reply #5 on: April 13, 2008, 05:22:50 pm »
Anyone know?
« Reply #6 on: April 13, 2008, 08:32:01 pm »
You do it when you render.  So when you go "Render>Render image..." and the popup box appears, there's an 'antialiased' option that you can uncheck.
mikeman118
« Reply #7 on: April 13, 2008, 08:59:27 pm »
Well, that works when rendering an image in object mode, but not a movie (although I haven't tried rendering an image in scene mode).  Is there any way to fix that, or do I just have to live with it?
Alpha2
« Reply #8 on: April 13, 2008, 09:58:32 pm »
You can render your movies without anti aliasing in scene mode but they have to be fairly high res videos or they're going to look horrible.
In scene mode: Render>Render Movie> in the Image menu where you can adjust the size of the movie you'll see a check box to turn of the Anti Aliasing.
« Reply #9 on: April 14, 2008, 05:40:24 am »
personally, i think the antialiased image looks fine.  if you tried rendering a video of that object without AA on, then it'd look awful, you'd get a sort of 'swimming textures' effect, which is nearly always a really bad thing :P
