Author Topic: Custom Rotating  (Read 14632 times)
dorothym
Custom Rotating
« on: August 01, 2018, 08:18:16 am »
Hello, I have what might be a bug.  The custom rotating only rotates an object about 1.00.
Does anyone else have this problem?  Thank you in advance for the help.  :)
AlecJames
Re: Custom Rotating
« Reply #1 on: August 02, 2018, 09:54:58 am »
What are you rotating / what values are you putting into the custom rotate?
dorothym
Re: Custom Rotating
« Reply #2 on: August 02, 2018, 06:34:31 pm »
Hi Alec.
Thank you for your reply.
First, I am rotating a 3d model from Daz.  I tried various values in the X, Y and Z-Axis areas.  (25, 45, 75 are just a few of the ones I've tried).  It doesn't matter what value I put in, it will only rotate my model about 1.00.  I have even downloaded the 1.00b version to make sure I was using the latest.  Am I doing something wrong?
AlecJames
Re: Custom Rotating
« Reply #3 on: August 03, 2018, 05:54:59 am »
Hi Dorothy
I think this is a know issue and it has been fixed in build v1.0b 1298+
I'm using build 1330 in which it works OK, see this thread http://www.anim8or.com/smf/index.php/topic,5667.0.html
dorothym
Re: Custom Rotating
« Reply #4 on: August 03, 2018, 06:28:10 am »
Alec, thank you so much!  It works perfectly now for me.  I feel really silly for not looking in that part of the forum, I will now look there to get the latest release.
And a BIG thank you to Steve.   8)
