Pages: 1 [2] 3 4 ... 11
Author Topic: v1.01 Development Release - Build 1403, August 29, 2022  (Read 391573 times)
chuft-captain
Re: v1.01 Development Release - Build 1318, January 25, 2018
« Reply #15 on: February 01, 2018, 07:30:17 pm »
Thought that would be the reason ... and it's a good thing, because often it's very helpful to rotate about the origin instead of the mesh's pivot ... and you know what I'm going to say next don't you ...   ;D 8) ... that it would be a good option to offer users when doing rotations of native meshes .. the option to rotate around the origin instead of the mesh center.
Claude
« Reply #16 on: February 01, 2018, 10:04:44 pm »
In axis mode,you can move and rotate the pivot point.
chuft-captain
« Reply #17 on: February 01, 2018, 10:20:06 pm »
Claude,
That's good to know ... but to borrow a phrase by Slartibartfast from Hitchhiker's Guide, "I don't know this 'Axis' mode of which you speak".
The only "modes" I have ever seen are Object, Figure, Sequence, Scene.
(I did say my knowledge of Anim8or features was not that broad, didn't I?  8) :D :D ::) )
Thanks!
« Last Edit: February 01, 2018, 10:30:58 pm by chuft-captain »
Claude
« Reply #18 on: February 01, 2018, 10:54:53 pm »
This button called Object/Axis mode lets you move an object's pivot or origin.
http://www.anim8or.com/learn/manual/buttons/b_axis_s.png
There's also some special functions in menu Edit/Pivot.
Sorry if my answer lacked details.
chuft-captain
« Reply #19 on: February 01, 2018, 11:38:05 pm »
Claude,
I can't find that button in my version (latest dev build 1318).
The only button that looks vaguely like it is in the Coord section (group of three) but when I hover over it, it says "World Coordinates <w>".
Is that the button you meant?
EDIT: Forget that, I think I just found the button you mean (just above the other one) ... sorry about that. I'll try that out to see it's effects.
« Last Edit: February 01, 2018, 11:40:25 pm by chuft-captain »
chuft-captain
« Reply #20 on: February 02, 2018, 12:08:59 am »
No need to apologize,
Tried that out, and it seems to do pretty much what I was suggesting to Steve, so it looks like he has already long ago implemented this, just in a form which I was unaware of.
(There are large sections of Anim8or functionality that I have barely touched on, so please excuse my ignorance.)
Thanks for the guidance. I learn something new about Anim8or every day, and it just keeps getting better and better!
chuft-captain
« Reply #21 on: February 02, 2018, 12:26:21 am »
Steve,
Sorry, I appear to have hijacked this thread a bit. If you want to keep this thread on topic, you can split off all my suggestions into a separate thread if you like (especially as it turns out you've already implemented most of my suggestions in some form or other a long time ago!)
CC
chuft-captain
« Reply #22 on: February 02, 2018, 05:03:22 am »
Steve,
I just did a very quick check of the Group/Layer changes, and on first glance it looks great!
Individual and combinations of layers can now be displayed or hidden at will, regardless of the status of Layer 0, and it appears that Layer 0 is no longer treated as a special case. (This I agree with completely.)
I'm sorry, I don't have time to test these changes in depth at the moment, but on a very cursory first glance it looks really good, and I'm amazed you got this done in such a short time since Christmas! Thanks a lot!
I'll do some more in-depth testing of the interaction between Group/Ungroup actions and layer memberships when I have more time, but it's looking good so far.
CC
itsstillthinking
« Reply #23 on: March 26, 2018, 12:26:57 am »
Was wondering if i could maybe add something for the next build? Something i always wanted was that when one is animating a object if one wants to move a object a short distance over a small length of time it will always make a "Hairpin" curve on the track that the object will follow. This can be annoying when animating objects as you have to manually find what the center of the object is so you can move it back to a strait line. Be great it it did not automatically do that! 8)
AlecJames
« Reply #24 on: March 26, 2018, 04:26:22 am »
I think Anim8or can already do what you want.  A key can be step, corner or smooth.
This next bit I need others to confirm - when a key is corner or step, it allows you to change the path in the graph editor, so with a corner key you can create literally a corner on the path but you have to make the corner in the graph editor. Simply changing the key type is not enough.
I've never got on well with graph editor, I'm going to spend some time with the manual later to try to understand why the UI does not always behave as I expect.
(Sometimes I cannot select a key to get the handles to appear - not sure why)
itsstillthinking
« Reply #25 on: March 26, 2018, 11:21:21 am »
Thanks everyone, il give it a try as soon as i can! Sorry everyone for all the questions :P
itsstillthinking
« Reply #26 on: March 28, 2018, 11:02:58 pm »
Been playing around with it and sadly it seems that using the graph editor cant really fix the problem :'(
AlecJames
« Reply #27 on: March 29, 2018, 03:38:33 am »
Can you post an example an8 file with the problem?  e.g. A single sphere in a scene with the "hairpin" you refer to?
itsstillthinking
« Reply #28 on: March 29, 2018, 08:16:34 pm »
Quickly threw together a example
AlecJames
« Reply #29 on: March 30, 2018, 08:28:52 am »
Moved keys discussion to "General anim8or forum" http://www.anim8or.com/smf/index.php/topic,5712.0.html
« Last Edit: March 30, 2018, 08:29:44 am by AlecJames »
