Author Topic: Rendering a series of png images  (Read 14339 times)
NoobJens007
    • www.jkh-art.dk
« on: July 10, 2017, 10:29:24 pm »
Hi there,
Im  new... Im going to use anim8or to create backgrounds for
a cartoon im making in macromedia flash 8. But Im having trouble
exporting a series of png images in anim8or 1.0.
Can anyone help?
thx
AlecJames
Re: Rendering a series of png images
« Reply #1 on: July 11, 2017, 08:27:18 am »
Hi NoobJens007
What is the problem?
« Reply #2 on: July 12, 2017, 06:35:41 am »
To make a series of .PNG images, use the Render->RenderMovie command and select the .PNG format. This will generate a sequence of  files namex xxx0000.png, xxx0001.png, .etc.
NoobJens007
    • www.jkh-art.dk
« Reply #3 on: July 15, 2017, 03:40:18 pm »
Ok thanks, I think I will just render single images and use them for backgrounds  in the animation.
It takes a long time on my computer to render a single image
selden
    • Modelling for Celestia
« Reply #4 on: July 16, 2017, 06:56:02 am »
Rendering time is going to depend on both the rendering software and the complexity of the scene.
You can export to obj and use a different renderer and/or you can render only some of the objects and use your favorite image processing software to composite separate images together.
Selden
NoobJens007
    • www.jkh-art.dk
« Reply #5 on: September 06, 2017, 06:05:33 am »
I found out that on both of my laptops the same issue occurs. I use a Surface pro, but switched to my big Asus laptop
because it is more powerful. This is what happens: when I open anim8or v.1.0 and edit something, then try to render
my movie as jpg images, nothing happens, except I can render 1 image. If I then close anim8or and go directly to rendering
my movie it works fine. I have windows 10 on both machines. Not really a problem, since I can just close and open the program
and then it works fine.
« Reply #6 on: September 06, 2017, 01:06:41 pm »
What version of Anim8or are you using? The initial v1.00 dated May 29, 2107 has a problem that causes hangs like this. If you have that version, try the one v1.00b dated August 27, 2017 which has a fix that should work for you.
NoobJens007
    • www.jkh-art.dk
« Reply #7 on: September 06, 2017, 03:23:32 pm »
Oh, thank you very much Steve!
By the way, I was on this forum 12 years ago and
Anim8or was great back then too, and Im filled with nostalgia and joy to be using it again.  :)
