Author Topic: Put a Modifier IN an object??....  (Read 7703 times)
Anim8er
« on: April 09, 2008, 03:54:10 pm »
Hi,
Yesterday, I tried to do the hand tutorial on the Anim8or site.  The only difference is that, I added a finger.  I'm on the last part, put the modifier that will bend the fingers.  I start by the little finger.
I did that:
But when I move to left view... The Modifier is there!
So I move the modifier:
And the modifier appear at the center of the hand!!  ??? ???
How can I place it in my little finger correctly?
Thanks
Re: Put a Modifier IN an object??....
« Reply #1 on: April 09, 2008, 04:03:04 pm »
it just seems like you're having trouble because of the position of your hand, go to edit --> Locate --> Centre about origin
and Edit --> Rotate --> Rotate none
that should make it a little easier
Anim8er
« Reply #2 on: April 09, 2008, 05:03:11 pm »
Oh!  We can do that?!  Place it in default position!  :) This will help me a lot.  But, I don't work, my modifier is still in the center of my hand...
« Reply #3 on: April 09, 2008, 11:18:21 pm »
Also, you can resize the modifier as well to make it bigger than the finger, but you dont want it so big it overlaps with the other finger.
Anim8er
« Reply #4 on: April 10, 2008, 08:03:36 pm »
This is what I did.  It work now, but it had modify a little the other finger.
