Author Topic: A description of the line colors in Wireframe view  (Read 14505 times)
Unobtainium
  • Engineer dabbling in various technical arts
« on: May 25, 2017, 08:56:37 am »
Regards selected models in "Object/Edit" mode. I've checked the Manual, I could not find a description for turquoise lines. I have a model optimized in Meshlab (poly reduced), upon investigating it in Anim8or I see three different colors while the original model shows only green lines. (My main motivation is trying to trace a physics bug in Unreal Engine 4 -- the orig. model stands upright, the optimized one tips over and spins on the ground).
Any insight is appreciated. :)
« Last Edit: May 25, 2017, 08:57:32 am by Unobtainium »
Re: A description of the line colors in Wireframe view
« Reply #1 on: May 25, 2017, 09:37:07 am »
Good point. I'll add something to the manual about this.
In Object/Edit mode the:
Turquoise (cyan) lines in a mesh are those that have two faces and will be shaded as a crease. The solid angle between the faces is greater than the Smooth Angle of the mesh.
White edges are shaded as smooth, and have a solid angle of less than the Smooth Angle.
Green edges have only one face.
Red edges have no faces.
