Author Topic: Weighting tool suggestion  (Read 15920 times)
Zileris
« on: May 05, 2017, 02:20:17 pm »
A tool to select the vertices, expand or subtract from the selection, select a bone, and apply a weight value directly. Or being able to select a set of vertices and have the weight paint brush only affect the selection
What this solves: Problems painting weights on overlapping or very close/dense areas of a model.
Kyle
Re: Weighting tool suggestion
« Reply #1 on: May 05, 2017, 08:18:30 pm »
This would be fine for lower poly stuff, but higher poly might need a more elegant solution. One things for sure though, anim8or could really use better rigging tools.
« Reply #2 on: June 17, 2017, 04:03:25 pm »
time ago i post something like this.
yes very usefull
« Reply #3 on: June 17, 2017, 04:25:35 pm »
You seem to be having Fun!!...... its not easy to weight paint anything in Anim8or, but gives you a good grounding when you migrate to other programs ie: ( Carrara.... weight painting uses 3d brush and is semi automatic when you add a sketeton so there is minimal painting!!)
But here`s some little tips that I use:
1:find a bone that does not have any movement then paint the whole model with that colour, then start on each individual joint.
2: also try using wireframe mode when doing intricate stuff you can see what missed and what needs painting
3: uncheck your skeleton during your painting process to see where you have overpainted.
Hope this helps. did you get to see the video ??
