Author Topic: Quick Texture Reload Feature?  (Read 13400 times)
lawrence
« on: April 09, 2008, 12:12:59 pm »
Here's a problem I have; when working on a texture in photoshop, every time I save it and want to see the updated texture on my model in Anim8or, I have to trawl through the material editor - surface texture editor - texture selector - delete the existing texture - then load the updated one. Having to do with every couple of minutes or so really slows down work-flow.
So I was wondering if there could be feature which reloads textures either in real-time or periodically or failing that, at least a button on any of the main tool bars which reloaded textures. What do you think Steve?
Re: Quick Texture Reload Feature?
« Reply #1 on: April 09, 2008, 12:22:05 pm »
I agree with this... I have the same problem when texturing :-[
I don't know how about periodical reloading... At least having a new "reload" button next to the "load" and "delete" buttons would help...
« Reply #2 on: April 09, 2008, 01:18:17 pm »
I completely agree with this as well.  Just a simple update button perhaps?
« Reply #3 on: April 09, 2008, 02:04:39 pm »
<proclamation>i hereby declare my full agreement with you all!</proclamation>  i've just been dealing with this exact issue this afternoon.
lawrence
« Reply #4 on: April 10, 2008, 02:47:37 pm »
The reason I think periodic reloading would be better than a button is so that you could have a small anim8or window in the corner and see updates basically in real-time as you paint in photoshop, without having to stop and switch windows.
« Reply #5 on: April 10, 2008, 05:17:00 pm »
Well, yes, but I'm sure that would slow down anim8or a lot.  Especially with large, high quality textures that already take a while to load.
« Reply #6 on: April 11, 2008, 05:06:37 am »
Ye, I got this problem so often. It would be helpfull to have a sort of reload button.
CobraSpectre
« Reply #7 on: April 11, 2008, 06:27:59 am »
This would be a nice feature when you are trying to test out how a texture will look.
Textures do take a while to load, so a "smart" texture reloader would be needed. The image you are working on externally would have to be saved over the same file name that anim8or is referencing. A hash of the current images would be stored, and hashes would be rechecked to see if they have changed, and if so reloaded.
« Reply #8 on: April 11, 2008, 08:02:38 pm »
What about a reload button/command that only reaload testure files whit a changed date?  That wouldn't use any time unless the texture was updated.
Alternately I might be able to add an auto load setting that updates textures whenever they are changed using a Windows notification message.  I don't know how to do this but I can probably figure it out.
« Reply #9 on: April 11, 2008, 08:50:23 pm »
Great idea Lawrence, cheers Steve!
