Author Topic: Is it possible to model a mesh from scratch using the ASL scripts?  (Read 14065 times)
lorenzo
I was wondering if it is possible to write a script that can model a mesh, is it possible or not? What command do I use? thanks :)
AlecJames
Re: Is it possible to model a mesh from scratch using the ASL scripts?
« Reply #1 on: March 13, 2017, 04:12:26 pm »
In the scripts database http://www.anim8or.com/smf/index.php/topic,1705.0.html there are scripts that create shapes.
Is this the kind of thing you mean?  You can look at the scripts to see example code / commands required.
Hope that helps.
