Pages: 1 [2]
Author Topic: Eggplant beginner blues (and greens)  (Read 26084 times)
Bugtrooper
Re: Eggplant beginner blues (and greens)
« Reply #15 on: September 15, 2009, 10:57:54 am »
Thanks! But where should I change the extrude options?
Pincho
« Reply #16 on: September 15, 2009, 11:24:30 am »
If you are trying to extrude multiple faces, you use the other extrude button, next to the one that you used. If you are trying to extrude just 1 face then you have made a mistake by picking all of the faces, and forgetting to click on a single face.
« Last Edit: September 15, 2009, 11:26:32 am by Pincho »
Bugtrooper
« Reply #17 on: September 15, 2009, 12:22:23 pm »
Sorry! I think my program makes this bug, because the 2 extrudes works the same.
I tried the other ne and it's work the same. So I think a re-install maybe help.
Bugtrooper
« Reply #18 on: September 15, 2009, 12:27:50 pm »
OK! I solved the problem is another way! Thanks for the help! I almost give up
Bugtrooper
« Reply #19 on: September 16, 2009, 02:31:43 am »
okay! Next problem. When I use the modifier on the plant, the "leg" moves
like this....
« Last Edit: September 16, 2009, 05:54:11 am by Bugtrooper »
« Reply #20 on: September 16, 2009, 01:23:52 pm »
My guess then, would be that you're clicking and dragging from the top down, am I correct?  The start and end points do matter with the modifier.  Try creating a new modifier and start by clicking and dragging from the bottom up.  It should fix your problem.
Bugtrooper
« Reply #21 on: September 16, 2009, 04:36:44 pm »
Thanks a lot!
Bugtrooper
« Reply #22 on: September 17, 2009, 01:52:23 am »
Here is my eggplant
I need to do it again but now I know how to.
Thanks all for the help!
Pages: 1 [2]
