Author Topic: Problem extruding on a path  (Read 5880 times)
JSmith_DumDumDumDumDum
« on: May 10, 2016, 10:01:26 pm »
Hello,
I'm trying to create a mesh by extruding Path_BooleanSubtractor along the path Path_tobeLathed. The final results is a flat curved plane (Result_thatIdon't_want), not a trapezoidal S-hook. It's the trap. S-hook that I want.
Unless I misunderstood, the instructions in the Anim8or manual stated that the starting point of the mesh needs to be at the orgin (0, 0, 0?). I think I did just that.
How do I fix this? Thanks.
Sluggs
  • Anim8or user since May 2004
    • Satans-Comrade
Re: Problem extruding on a path
« Reply #1 on: September 06, 2016, 11:42:15 pm »
On the first path, you have to "Build/Join Splines" otherwise the final mesh will be messy. :o
PS. Your main path is faulty and you should make a fresh one.
« Last Edit: September 06, 2016, 11:53:46 pm by Sluggs »
