Author Topic: How to retrieve a texture's BlendMode ?  (Read 15614 times)
selden
    • Modelling for Celestia
« on: October 28, 2015, 07:05:33 pm »
How can I retrieve the BlendMode associated with a Texture in the export script that I'm working on?
(I'm trying to improve the functionality of my CMOD export script.)
The documentation at http://anim8or.com/scripts/spec/index.html shows "int GetBlendMode(int mode);" to be an element of  "struct material" except that can't be right. That would allow only one BlendMode per material, while there actually can be many BlendModes in a material, one associated with each of a Material's Textures. Unfortunately, my attempts to retrieve it as if it were an element of a texture structure don't work. :(
Selden
Claude
Re: How to retrieve a texture's BlendMode ?
« Reply #1 on: October 28, 2015, 07:50:52 pm »
Try:
int GetBlendMode(int kind, int mode);
If it's implemented, it should be similar to
int SetBlendMode(int kind, int mode);
« Reply #2 on: October 28, 2015, 08:06:29 pm »
There is a typo in the spec.  The real description should be:
int material.GetBlendMode(int kind);
where kind is one of:
enum {
    TEXTURE_AMBIENT,
    TEXTURE_DIFFUSE,
    TEXTURE_SPECULAR,
    TEXTURE_EMISSIVE,
    TEXTURE_TRANSPARENCY,
    TEXTURE_BUMPMAP,
    TEXTURE_ENVIRONMENT,
and the return value:
enum BlendMode {
    BLEND_MODE_DECAL = 0,
    BLEND_MODE_DARKEN = 1,
    BLEND_MODE_LIGHTEN = 2,
An example:
mode = lMaterial.GetBlendMode(TEXTURE_DIFFUSE);
Claude
« Reply #3 on: October 28, 2015, 08:35:36 pm »
I didn't think about this long enough to see that
int mode was not required,but I was wondering
what int SetBlendMode() and int SetAlphaMode()
would return.
selden
« Reply #4 on: October 28, 2015, 11:42:43 pm »
Steve,
Thanks, a lot! That did exactly what I wanted. I was able implement "decal" and "darken". Unfortunately, Celestia does not provide a way to add colors, only multiply, so I was unable to implement "lighten".
The revised CMOD exporter is now available at http://www.classe.cornell.edu/~seb/celestia/modelling.html#4.1
Selden
