Author Topic: A One Sided Issue???  (Read 14833 times)
argo34116
« on: October 26, 2015, 02:24:04 am »
I guess I am just too much of a perfectionist. I want both sides to appear the same (Fin and wing markings) on a 3d model of colonial vipers from Battlestar Galactica Tos. The left side (see image) is good. Everything in the right place. When I attempt to duplicate these markings on the right side as appropriate, I come close (see image)As you can see,but it is not quite right. How can I solve this? I have included the textures and the 3d model here. Thank you.
argo34116
Re: A One Sided Issue???
« Reply #1 on: October 26, 2015, 02:28:49 am »
Here is the 3ds model
argo34116
« Reply #2 on: October 26, 2015, 03:34:56 am »
And..... The textures
lppena
  • Anim8or, does a body good.
« Reply #3 on: October 26, 2015, 06:41:17 am »
They look backwards from one side to the other. Looks like you might need to flip the texture on the other side 180 degrees?
I'm not familiar with how Anim8or does this, but it looks like you might try planar mapping the left and right sides independently?
Maybe you might also try dividing the model down the middle and use the mirror modeling tool to duplicate the other side with the texture applied?
« Last Edit: October 26, 2015, 06:42:24 am by lppena »
selden
    • Modelling for Celestia
« Reply #4 on: October 26, 2015, 08:23:25 am »
I agree with lppena: I'd delete the wing that's messed up and replace it by a mirror image of the other wing.
When an object is perfectly symmetrical, it sometimes can be easiest to create only half of it and combine that half with its mirror image.
Selden
« Reply #5 on: October 26, 2015, 12:13:56 pm »
You can flip texture image vertically in the Materials dialog. Click on the Textures button, select the texture and check the "Invert Images" box.
argo34116
« Reply #6 on: October 26, 2015, 03:37:53 pm »
I did the invert image and the image on the right side is the best I could do with it. It was worse before doing invert image.
argo34116
« Reply #7 on: October 26, 2015, 03:39:48 pm »
Perhaps someone here can do better with what I have provided here in attachments? And provide the results here? I am new to this. Thank you
lppena
« Reply #8 on: October 27, 2015, 07:34:30 am »
Your model group has a lot polygons bro. I tried messing with it in Caligari Truespace but the poly count or the model itself has some issues. I also tried importing it into Anim8or but didn't see the model group.
selden
« Reply #9 on: October 27, 2015, 10:53:28 am »
The 3DS model that was uploaded contained multiple spacecraft at a random orientation within the coordinate system. When working on a model, you should limit the work to a single model which is carefully aligned with the coordinate system. Then, as the very last step, when it has been modified to be as you want it, you can use it to create an entirely new model consisting of multiple copies of the original.
I deleted two of the models and aligned the remaining one with Anim8or's coordinate system. I then un-grouped the model, deleted the messed up wing and mirrored the one that was OK. (Since you didn't include any surface texture images, I made my own with arrows on it so I could judge its alignment.)
I've attached a zip of the resulting .an8 model. Like the 3DS, it requires two textures: "wing.jpg" and "engine thing.jpg"
Selden
argo34116
« Reply #10 on: October 29, 2015, 05:11:04 am »
The wings are OK (thank you),but the fin markings are incorrect on the right side. Is there a tutorial (maybe a video) that can walk me thru how to mirror the left side onto the right? I have attempted this with "Build then selecting mirror image" I can then ungroup, select the mirror image and move it into position on the right,but I have been unable to get the image to join with the fin on that side. There is a gap. Thank you everyone for your help here.
selden
« Reply #11 on: October 29, 2015, 10:00:42 am »
I won't have time to look at it in detail until this evening, but briefly, this is what I'd try to do:
ungroup the model
copy the tail to two new objects
in point-edit mode,
delete all of the points from the left half of one the new tail objects
delete all of the points from the right half of the other new tail object
  be sure to leave a one-point-wide border overlap in both halves.
fix the broken half
copy the repaired half into the object containing the previously OK half-tail object
merge the two halves into one  solid
replace the messed up tail in the original object with this repaired tail
Selden
argo34116
« Reply #12 on: October 29, 2015, 03:24:26 pm »
Thank you. That sounds a bit complicated and above my head right now. I am just getting started with this.
selden
« Reply #13 on: October 29, 2015, 05:57:28 pm »
Close inspection of the original 3ds that you provided (containing three copies of the Viper model) revealed that the Viper's model was damaged. Materials were missing, for example, the model was slightly out-of-kilter, and somehow the glass panes of the canopy had gotten out of registration with one another even though they're a single object.
I fixed a very few of the problems so the model superficially looks OK, but I didn't fix the more difficult ones. EG I didn't fix the canopy's glass, although I did make it transparent again.
Below is the 7zipped .an8 model of a single Viper, aligned with Anim8or's axes. and with its stripes restored. I've included the textures that it needs, the ones that I added back into it, which are only a few of the textures that it presumably started with. Below that are screengrabs showing how it looks in Anim8or and Celestia.
p.s. Applying the textures to provide the stripes actually was relatively straight forward.
Part of the damage to the model was the way the textures were mapped onto the right-side engine, the right-side upper and lower wing parts and the right side of the vertical fin. I deleted the damaged objects, selected their left-side counterparts (one at a time), and did a "build -> mirror image... x" to create their replacements.
I created materials names "engine_striped" and "fin" and selected the appropriate texture images in their material definitions. I was pleasantly surprised that simply selecting the appropriate parts of the model and "Apply" drew the images on the parts correctly. Apparently the texture mappings had been preserved on those parts even though the associated materials had been un-defined.
« Last Edit: October 29, 2015, 06:07:10 pm by selden »
Selden
argo34116
« Reply #14 on: October 30, 2015, 07:37:53 am »
Looks Great. That did the trick. thank you for your help everyone. Much appreciated.
