Pages: 1 [2]
Author Topic: Trackball Rotation for Bones  (Read 78735 times)
Re: Trackball Rotation for Bones
« Reply #15 on: May 03, 2015, 07:44:25 am »
captaindrewi, maybe your computer has malware on it, or something else. Does v0.98 work smoothly? You can check also if your antivirus is getting in the way by disabling it beforehand.
« Last Edit: May 03, 2015, 07:46:42 am by Raxx »
« Reply #16 on: May 03, 2015, 10:39:50 am »
thanks Raxproblem seems to be solved by updating driver/drivers
« Reply #17 on: May 03, 2015, 03:15:00 pm »
cooldude234 and johnar: I can now reproduce the problem with bone rotation in Scene mode. I'll fix it and post an update.
nemyax
« Reply #18 on: May 04, 2015, 04:49:43 pm »
neirao: Oops, you're right, that's a bug - the length won't change for then "Edit Bone" tool.  I'll fix it.
Could you also add the feature that cooldude234 illustrated in this post?
« Reply #19 on: May 06, 2015, 09:55:16 pm »
I posted build 1176 with a new trackball that uses the current coordinate system for rotations.  You can select either world, local or screen using the three buttons in the left-hand toolbar.  It doesn't look much like a sphere when using screen coordinates, just a crossed circle :( .
« Reply #20 on: May 06, 2015, 10:22:42 pm »
  The scene mode bug posted above has been fixed. Thanks steve
 Personally, i don't mind how it looks now. Its still functional and easy to use.
 Thumbs up, will keep in touch, and thanks again.
« Last Edit: May 06, 2015, 10:23:25 pm by johnar »
« Reply #21 on: May 07, 2015, 09:12:42 am »
Hey Steve, seems to work fine in all modes. The screen coord widget is how I imagined it'd be, I think it's fine.
The outer screen Z-axis circle doesn't work anymore though, is that intentional? It's useful to have that regardless of what coord system is selected.
Lastly and kind of related, I notice that mouse-over highlighting doesn't work for anything when fast select is off. I always work in fast select mode so I never noticed, but I think it's a useful feature to implement universally.
« Reply #22 on: May 07, 2015, 09:36:10 am »
I disabled the out ring but didn't delete any code so it's simple to enable again.
Mouse-over highlighting would need quite a bit of tweaking when fast-select is off. You don't want to highlight things that won't be affected. But it's a good idea.
« Reply #23 on: May 07, 2015, 01:37:58 pm »
I think at minimum, it should be enabled for the select tool and the widget axes.
Pages: 1 [2]
