Author Topic: Converting Text Objects to Splines  (Read 6567 times)
ronaldefarmer
    • Ron's Website
« on: April 09, 2015, 02:58:49 pm »
Here is something that I have always wondered: Why is it that when text objects are converted to splines and then joined, smooth nodes are changed to corners? (example on the right)
« Last Edit: April 13, 2015, 12:33:19 am by ronaldefarmer »
ronaldefarmer
    • Ron's Website
Re: Converting Text Objects Splines
« Reply #1 on: April 13, 2015, 12:32:57 am »
So here is what I have discovered: If you convert a text object to a spline, nodes that have the appearance of being smooth are actually shown as corners in the "knot parameters" dialogue. When these splines are filled or extruded individually, they continue to have a smooth appearance. However, combining two or more splines causes all nodes to look like corners so that when filled or extruded, they don't have the desired appearance.
« Last Edit: April 13, 2015, 12:39:45 am by ronaldefarmer »
Re: Converting Text Objects to Splines
« Reply #2 on: April 13, 2015, 02:18:24 pm »
I'll fix this.  When I added support for Build->ConvertToMesh of splines I fixed a similar problem but I missed this.
#098-066 - Joining Splines converts all edges to straight lines.
ronaldefarmer
    • Ron's Website
« Reply #3 on: April 13, 2015, 05:09:32 pm »
Thanks!
