Author Topic: So, I downloaded Terranim8or...  (Read 13017 times)
BladeMan.EXE
  • Battle Routine, Set!
« on: April 05, 2015, 03:43:17 pm »
And so far, I'm lost. No more lost than I was when I first started with Anim8or though.
Anyone got any tips or know where I could find a tutorial?
Re: So, I downloaded Terranim8or...
« Reply #1 on: April 05, 2015, 09:43:07 pm »
Hi BladeMan,
unfortunately the official page of Terranim8or no longer exists,  ::)
no is so hard using Terranim8or... in start i think the same..
i found here in my computer a tutorial about "Creating and Texturing Terrains with Terranim8or"
please check the "Attachement" and have another tutorial in video about "animated background" check
the video on youtube:
below my olds tests using the software :)
BladeMan.EXE
« Reply #2 on: April 06, 2015, 01:37:36 am »
Ohh, I get it. You're supposed to use it to add effect to existing projects. I'm supposed to make a plane in Anim8or before I make it into a terrain in Terranim8or.
Come to think of it, that should've been obvious... :-[
Well, regardless, the video made some other things clearer too. Also, cool that I can use it to make animated textures for backgrounds or screens. :D
BladeMan.EXE
« Reply #3 on: April 06, 2015, 12:43:01 pm »
Having some trouble with the special effects...
1. I can't figure out how to change the colors of the particles for trails, flames or explosions. I tried replicating a teapot shattering with the explosion, and the debris still looked like it was slightly on fire. I tried using trails for a waterfall effect, and the water was grey.
2. Whenever I try using flames, it makes them completely invisible unless you're looking at them in the wire frame view mode.
« Reply #4 on: April 06, 2015, 01:01:43 pm »
see this my old topic, i show how to change the particle fire in Anim8or (after generate in Terranim8or)
http://www.anim8or.com/smf/index.php?topic=2939.0
EDIT:+fire and smoke -  http://www.anim8or.com/smf/index.php?topic=1805.0
« Last Edit: April 06, 2015, 01:17:35 pm by neirao »
BladeMan.EXE
« Reply #5 on: April 06, 2015, 01:20:49 pm »
Umm... I still don't get it. The problem with the fire isn't the particles being flat. The problem is that the particles are invisible.
And how am I supposed to change the colors of the particles? They only appear in the scene editor, which doesn't have a materials window.
« Reply #6 on: April 06, 2015, 01:34:21 pm »
the particle is a "simple object" so you need goto to ..
MODE--> OBJECT -->> OBJECT --> find/select your object (object01)
show material editor (CTRL+M) --> in TOP of this menu you have 2 options (FILE and OBJECT)
select OBJECT.. DOUBLE CLICK in texture -->  select DIFFUSE and DRAG in bottom the colors control for CHANGE THE COLOR!!
ps: same INVISIBLE you can use "RENDER" for see the color in object ok!!
« Last Edit: April 06, 2015, 01:39:22 pm by neirao »
BladeMan.EXE
« Reply #7 on: April 06, 2015, 08:28:02 pm »
Still haven't figured out how to make the fire particles visible without making them look wrong, but I have figured out several problems with them, one of which being that the texture for them wasn't in the texture directory.
But now that I know that the particles are stored as objects in the project file, I can just replace them with orange glowing spheres/drops/etc, and I'm liking the results so far.
Thanks! :D
« Last Edit: April 06, 2015, 08:30:22 pm by BladeMan.EXE »
rounder
« Reply #8 on: April 07, 2015, 03:50:09 pm »
The entire terranim8or site is available for DL here
http://www.biederman.net/leslie/ter.zip
I have not been able to get a hold of les to fix some things on it after I moved hosts. I am happy to host it, but I believe it was infected with malware at some point and needs to be looked over and sorted before i put it back up.
« Reply #9 on: April 07, 2015, 05:47:22 pm »
I'm fine cleaning it up. However, the archive you uploaded can't be extracted.
