Author Topic: Deleting a sequence from a scene  (Read 10184 times)
AlecJames
« on: January 16, 2015, 07:11:50 am »
If I have a sequence on a figure in a scene, how do I delete the sequence?  I tried selecting it in the time track and pressing delete, all the keys go but if I save the file and reload they re-appear.
This happens on version 1150.  It didn't want to call it a bug since I don't know how to delete a sequence.
thanks
A
Re: Deleting a sequence from a scene
« Reply #1 on: January 16, 2015, 12:40:33 pm »
i've been using Anim8or for 12 years, and never figured this one out either - it's not just Build 1150!
« Reply #2 on: January 16, 2015, 04:26:49 pm »
 You can try selecting a sequence key and copy/pasting it back into a sequence. Anim8or will ask if you want to convert the sequence keys into ordinary keys. Click ok.
 You've still got the keys showing, but they can now be deleted as per normal keys. (use 'cut')
 To select a block of normal keys ,  select the first to be deleted, hold shift and click the last.
 It would actually be a good thing to have a 'delete sequence' option tho.
« Last Edit: January 16, 2015, 04:31:02 pm by johnar »
« Reply #3 on: January 16, 2015, 04:55:16 pm »
didn't know about that workaround, johnar - thanks for the tip!
AlecJames
« Reply #4 on: January 17, 2015, 03:55:35 am »
Thanks for that work around johnar, its better than mine (I open the anim8or file and delete the sequence in the file :o)
« Reply #5 on: January 17, 2015, 05:11:49 am »
thecolclough-AlecJames
 You're very welcome. Glad i could help.
« Last Edit: January 17, 2015, 06:49:09 am by johnar »
« Reply #6 on: February 21, 2015, 07:16:45 pm »
#098-062-Unable to delete Sequences in Scene Editor.
Wow, this really needs to be fixed!  I'm on it.
