Author Topic: Biiig problem png textures  (Read 13217 times)
neodelito
    • ModuloSoporte
« on: December 07, 2014, 09:01:03 pm »
Hi i make many models using this method in anim8or.
1.- i make a base model in ami8or, and texture them using a jpg image
2.- export to obj an apply a png image
3.- Works god....
but now i have this problem, model is not export the same form or structure... all faces are inversed..
look..
any idea???
thanks for your time
I
MvGulik
  • [... Lost in Space ...]
Re: Biiig problem png textures
« Reply #1 on: December 14, 2014, 08:59:39 am »
neodelito: Looking at your post I don't see anything that directly points to a specific Anim8or problem here. Those first two images don't look like there coming from Anim8or, supporting the conclusion is not a Anim8or related problem. (I did try to see if I could find something, but whiteout result.)
Options:
- Add more info that show it is a Anim8or issue.
- Request this topic to be moved to the general forum. Which might draw in more help to your problem. (And if it turns out there is a specific Animator problem, you can just submit what was found at that point.)
Mmm, nevermind. Seems I did something wrong ... again.
« Last Edit: December 14, 2014, 01:46:29 pm by MvGulik »
« Reply #2 on: December 14, 2014, 11:18:35 am »
Can you send my the textures and a model that shows the problem?
