Author Topic: [fixed] Figure(mode),Material flip,Render-Image.  (Read 12284 times)
MvGulik
  • [... Lost in Space ...]
« on: November 24, 2014, 06:31:46 am »
#098-xxx - ?:NamedComRec Material binding bug.
Fixed: v0.9.8 build 1140
[-] Figure(mode),Material flip,Render-Image.
A little leftover part in relation to a issue that was fixed in(or before) build 1061.
Initial issue: After editing, or creating, a material in figure mode. Any used Object-materials on the objects in the figure would switch to using the same-named Figure-materials (or flip to default material). (for Figure and Sequence Workspace, which was fixed.)
The leftover part in this case is "Render image"* in Figure and Sequence mode.
*) Only for "Art Ray Tracer" render. The other two render modes (Scanline & OpenGL) are not affected by this.
- Version/Built: (1061) .. 1139.
- OS: XP & Vista
[steps]
- ObjectMode: Create mesh, create material01(Red), apply material to mesh.
- FigureMode: Add bone01, create material01(not Red), Add Object to bone01.
- (save/load)(ART test image render)
- Open Figure material01 and close with OK.
* ART Rendered image is rendered with Figure-material01 instead of Object-material01. (Figure and Sequence mode only)
*build update*
*fixed update*
« Last Edit: December 06, 2014, 08:35:15 am by MvGulik »
Re: [-] Figure(mode),Material flip,Render-Image.
« Reply #1 on: November 30, 2014, 09:28:42 pm »
This will be fixed in build 1140 :)
