Author Topic: movie  (Read 8870 times)
silverlit
movie
« on: April 02, 2008, 01:25:45 pm »
hi i have now learned how to make figures and stuff with anim8or
and i have seen lot of movies with it can some1 tell me how to make
a movie? ???
also import the figures, get into the movie part of the program,
moving figures, and save it as a video file?
Re: movie
« Reply #1 on: April 02, 2008, 01:33:43 pm »
well this teaches animation:
and the second part is...the next part, i don't have any good links to other help you've requested, but i'm sure a bit of googling could help...
Re: movie
« Reply #2 on: April 02, 2008, 02:31:26 pm »
Re: movie
« Reply #3 on: April 02, 2008, 02:47:24 pm »
i'm currently trying to teach a friend the rudiments of anim8or - he's not doing too badly, but he seems to keep forgetting where the 'mode' menu is.  it's quite important, as that's how you get to 'the movie part of the program', aka. 'scene mode'.  In the top menu bar, click 'Mode' (on the left, next to 'Edit'), and select 'Scene' - that'll take you to the bit where you can make stuff move.  Once you're in there, you can add an object or figure to the scene by going to 'Build' (about half-way along the top menu bar), and selecting 'Add Object' or 'Add Figure'.  obviously, that only works if you've already built some objects and/or figures!
i won't write a ton about animating scenes here, as there are plenty of tutorials out there that explain all that, but once you've got your scene finished, you can save a video file of it by first making sure you're looking at it from the right view (usually you want to be in Camera view), then going to the 'Render' menu, and choosing 'Render Movie'.  that'll bring up a dialog which lets you set up your video (eg. file name, frame size, and stuff like that), then when you 'OK' that, it'll give you a list of codecs.  the default is 'Uncompressed', which will take up lots of hard disk space, but give you maximum image quality.  If you want a smaller file size, you might want to have a look at other codecs.  once you 'OK' your choice of codec, you can then sit back and watch at your leisure, while anim8or renders your scene into a finished video clip, which can then be played back in Windows Media Player (or whatever), and/or put into a video editing program (if you've got Windows XP, then Microsoft Movie Maker should have come with your pc, it's not great, but it'll do the job if you haven't got another one).
hope that helps  :)
Alpha2
Re: movie
« Reply #4 on: April 02, 2008, 08:28:46 pm »
I've come and gone from Anim8or like 6 times every time because I felt that it was overly complicated but comming back because it's still the simplest of all 3D programs interms of getting something built and animating it.
This time I've come back with a realization that in many ways it works very much like Macromedia Flash, if you consider the sequence mode is basically like creating a looping animation that you'd store in the library. Then you apply that sequence to the figure as many times and you need to see it in the final rendered animation.
a simple example: If you need a character to walk five paces, create a single "left,right" step animation in sequence mode and then apply it to the figure five times in scene mode, then all you have to do is hit the Keyframe button, add enough frames to the timeline for the walk and decide where the character should be on the first frame and where he should be at the last frame of the entire animation.
I'm hopeing using this simple method of thought will help me finally make something with the program after years of getting frustrated with it for so long.
Re: movie
« Reply #5 on: April 03, 2008, 11:35:50 am »
yeah, lots of good suggestions this time, which is better than "read the manual"   it's wierd, i've just realised i've been moving up a ladder of animation, first i started with paint and jasc animation shop, then pivot, then my dad got flash 5 for free, now i'm into 3d, i never noticed, odd isn't it, i also forgot to tell you that that tutorial is in 2 parts on youtube
